which pw7 wall mount
Discussion in 'Home Cinema Buying & Building' started by cjarmstrong, Apr 28, 2005.
  1. cjarmstrong
    cjarmstrong
    could anyone recommend a good flush wall mount for pw7, seems to be lots of the panasonic ones on flea bay the moment for around £100. thanks.
  2. geewhizz
    geewhizz
    Jan 2, 2005
    2,458
    +89
  3. mh123
    mh123
    Apr 2, 2005
    696
    Offshore UK
    +72
    You can unscrew the grip handles from the Panny to save yourself another half an inch :smashin:
    I guess you just left them on for convenience whilst decorating.
