If none of the choices suggested can be turned off totally wthout unpluging get a switched extension lead for it, so you can turn it off completely
The purpose of the PVR is that it will turn on and off as needed to record the programs you've scheduled.
Having used the Sagem DVR62160SL-T for a few more days I've come across a few niggles worth mentioning:-
The EPG is very slow - I'm not sure if it repopulates everytime you switch on from stand-by or what - but when you first go into the EPG it will sometimes only show some of the programs in the listing for the channel and can take a while to update.
I have had one recording 'lock-up' on me - this was a film showing a length of nearly 2 hours where I could not move past 56 minutes in. I was editing the recording at the time (I had trimmed the adverts etc. from the start and was going to the end to trim that) so that may have caused the issue. Other edits have been fine.
The FastForward and Rewind speeds are little harsh - forward we have 1x, 4x, 10x, 60x, 300x and 600x and in reverse we have 4x, 10x, 60x, 300x, 600x - It's easy to press one time too many and fly though half the program rather than just the adverts.
Perhaps I will be wishing later that I'd gone for the £179 Humax or the Digihome; but given the way everything is repeated and re-repeated nowadays losing the occasional program is not too big an issue.
[Edit] A month on and I've had no more 'lock ups' - The slow displaying EPG is definitely annoying and I still end up skipping 10 minutes past the adverts when I press FF once too often
[Edit] Three months further on; I received a software update about a week ago (0.6.4.d MH) - this has vastly improved the machine (so much sothat I thought it worth updating this post):-
- The tuner seems to have been improved - I'd been missing some muxes & after the update they were available to me
- The epg seems faster and easier to scan.
- Recordings can be stored in sub-folders, the listing can be sorted alphabetically or by recording date and can be more easily scanned.
- Recordings can be exported to USB in MPEG2 format (& watched on your PC or oimported into another PVR). I haven't experimented with the USB import facitlity.
- The Next /Previous Chapter keys now skip through the recording in 5 minute jumps - not the best 'skip' function but better than none
The media player still only supports mp3 (not wma) music files and the media interface is still too slow to be really useable...
