Which PSU ???????
Discussion in 'Computer Components' started by PJD007, May 27, 2008.
  1. PJD007
    PJD007
    Jun 10, 2005
    219
    Ok so here is my spec:
    ANTEC P182 CASE
    INTEL CORE 2 DUO E8400 1333FSB SKT775
    ASUS SKT-775 P5KC
    GEIL 4GB DDR2 800 CL5.0 DUAL CHANNEL BLACK DRAGON
    XPERTVISION 256MB RADEON HD 3850 HDMI PCI-E 2.0
    ASUS DVD 18x S-ATA DVD-E818AT BLACK RET 2 BEZELS BLACK/SILVER
    ASUS DVD±RW 20x S-ATA DRW-2014L1T BLACK LIGHTSCRIBE OEM
    2X SATA HDD
    Don't want to spend a fortune but want a quiet realiable PSU, I think 600W.
    Advice appreciated.
    Thanks.
  2. Th4tch
    Th4tch
    Mar 15, 2008
    23
    The popular choice for a quiet PSU seems to be the Corsair 500 and 620 watt versions.
    I'm going to go for the 520W at about 65 quid..i think you'll be looking at £85 for the 600W, its not cheap, bit i really want to make sure mine is quiet.
  3. sunderland
    sunderland
    Oct 29, 2003
    4,532
    2
    83
    northeast england
    +242
    the corsair 520w will do just fine for you and is very quiet
  4. PJD007
    PJD007
    Jun 10, 2005
    219
    Thanks guys.
  5. booyaka
    booyaka
    Sep 26, 2002
    10,843
    +3,356
    agreed - corsair 520W perfect:thumbsup:
  6. overkill
    overkill
    Nov 6, 2003
    11,855
    Murkeyside
    +1,207
    Another vote, if is quiet you want, for the Corsair 520HX. If the slightly greater noise is no problem, the Coolermaster 650w Extreme power is cheaper, holds the voltage just as well, and has that little bit more grunt.
  7. tinners
    tinners
    May 22, 2006
    3,289
    Bucks
    +242
    haha this forum's starting to sound like a Corsair advert :) another vote here (I have 3 of them !)
  8. sunderland
    sunderland
    Oct 29, 2003
    4,532
    2
    83
    northeast england
    +242
    well you have to go for the best tinners m8
  9. Brausch
    Brausch
    Apr 12, 2007
    333
    28
    +32
  10. davidm2
    davidm2
    Sep 14, 2007
    600
    +96
    I rather like the Corsair or Seasonics as well.
