Which PSU?
Discussion in 'Computer Components' started by MartinY, Apr 18, 2005.
  1. MartinY
    MartinY
    Apr 8, 2005
    10
    I'm looking for a PSU for my new HTPC build :D
    Spec: P4 650 (3.4 Ghz, 64bit), Asus P5AD2-E-Premium MOBO and the 256Mb XFX GeForce 6800. Approx 2.4 Tb of hard drive space (8x 300Mb hard drives).
    Could run either a fan (if quiet) or a fanless PSU as the box will not be in the lounge. What power and make (and model!) should I go for?
    Confused by choice!
    Martin
  2. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    Akasa Paxpower 460W? Seems to get good reviews. I have the 400W version and it's as quiet as a mouse (although it doesn't squeak.)
    Once I'd bought it though, had to go around searching for quiet everything else, and now my hard drives are doing my nut!!!
  3. MikeFish
    MikeFish
    I'm using the Akasa 460w, and while it seemed quiet when I had a fanned ATi card, when I swapped it for a fanless Nvidia, it started to make a lot more noise. The Nvidia cards require more power I'm told, so guess that makes the PSU work harder and fan spin faster.
    With a power hungry system like yours I'd be catious (I'm assuming the 650 processer is hungrier than my 540) about using the Akasa.
