Which PS2 Scart lead?
Discussion in 'Playstation Forums' started by Dan666, Oct 29, 2003.
  1. Dan666
    Dan666
    Jul 4, 2002
    144
    Im looking for a Scart lead for my PS2 - so far Ive found items by 4Gamers, Blaze, Gameplay etc, as well as the overpriced official Sony item.
    I know all of these use RGB signals, but do they all support widescreen switching and channel selection signals like other Scart equipment?
    I would think that the Sony item would do this but Im not keen on shelling out £30 if the other makes have the same capabilities for around £5-£15.
  2. othello
    othello
    Oct 9, 2001
    147
    16
    england
    i use the blaze scart from gameplay on my widescreen tv.. very good bit of kit..
  3. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    I have a full loaded Gameplay RGB scart for ps2 new & boxed yours at a price I was thinking about £7 inc P&P pm me if interested
    maybe we come to a deal
    :smashin:
  4. CMcK
    CMcK
    Mar 18, 2003
    409
    Scotland
    +30
    I bought the official Sony cable for £30 and it's certainly better than the third party effort I had before but not £15 worth of better.
    I don't rate the output from the PS2 as being much good and games using the half height buffer just compound the issue.
  5. wod
    wod
    Sep 7, 2003
    196
    +3
    the blaze ultimate scart lead is a good one at 15 quid in hmv , game etc
  6. Dan666
    Dan666
    Jul 4, 2002
    144
    Well Ive just bought a Gamester Professional AV/Scart Cable from Comet for £9.95.
    The quality oif the cable and connectors is pretty good, the plug Scart plug itself is metal - The picture is now definatly sharper and more vibrant than composite.
    Unfortunatley, It doesnt seem to have the two features I've described above - it doesnt switch the TV to the correct AV input when the PS2 is switched on, and it wont switch the TV to Widescreen when it should. I currently have the screen setting (in the PS2s configuration menu) set to Full, although I have tried 16:9 and this hasnt worked either. I've been testing it with GT3 which is set to 16:9.
    Im assuming the PS2 does ouput these signals in the first place... ? Do I have everything set correctly? Or does this cable need to go back???
  7. Veganian
    Veganian
    Jan 7, 2011
    I know I'm more than 7 years late to this thread but I know there are still a lot of PS2 users out there so I thought I'd reply anyway!
    I don't rate the output from the PS2 much either. I have both types (original and slimline) and the video output is pretty rubbish on both. Having said that, upgrading to a decent RGB cable plugged into an RGB input on the TV makes a huge improvement to the picture quality (but still no auto aspect switching etc.) I bought a Gamester Pro gold RGB scart last year for a fiver. It was brilliant but also a bit dodgy, since it's now developed a fault.
    The optical audio output from the PS2 is rubbish too, since they didn't even use dolby digital stereo or surround. Just plain old stereo, so my surround processor uses Pro Logic (ancient technology!) unless I switch it to stereo mode. This makes the surround output option on the PS2 pointless. Unless I'm missing something, which I probably am!
    Still, it remains amazing for the games, which is why I still have the PS2!
  8. nebno6
    nebno6
    Apr 20, 2010
    23
    component is the way to go as most modern TVs can handle it
  9. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    I bought a boxed Joytech PS2 RGB scart lead from poundland recently. It was the poundland in taunton, somerset. Seemed good value and of course can be used with ps1 and ps3 too. Has the lightgun connector as well. However I haven't actually tried it yet but if your near a poundland worth a look.
  10. ahxnccj
    ahxnccj
    Feb 1, 2011
    4
    i alwayz use the blaze scart from gameplay on my t.v.
  11. Alty08
    Alty08
    Jan 16, 2009
    1,453
    Home....
    +274
    fyi:
