Which Pronto ???
forever
Pls help, looking for a pronto to control my 300 multidisk changer, using the nudelist software.
My question is which one do I get ???
Not looking to break the bank, but would also like it to replace my 6 rc's.
Also is the Marantz the same thing?? Will it run the nudelist software ?
Thanks for any help
Loada
The cheapest way is to get one of the "classic" black & white Prontos - either the RU890 or the RU940. There are also the corresponding Marantz "Pronto" remotes available; the RC5000 and RC5000i respectively. All are pretty much the same thing and can be found pretty cheaply on eBay. SuperNudeList will work perfectly with them.
It's under conversion to the new-generation Pronto remote (the RU950). Until that's complete, I suggest you stick with the tried and test "classic" Prontos.
HTH
Rory.
Loada
eBay. Always a brace of them on there. Search for "Pronto" - look for the RU890 or RU940.
