Which Pronto?
Discussion in 'Home Cinema Control & Remote Controls' started by andy76, Dec 16, 2003.
  1. andy76
    andy76
    Having looked around at buying a Pronto I am a bit confused with the models available.
    Philips website lists two - the RU930 and the RU970.
    The RU930 seems the best for me but there also seems to be available an RU940 and RU950- what are these model?
    Is one a replacement for the RU930?
    For those of you who have one, is the RU930 a good version to have?
    Found it (potentially) for £133 which seems very low. OUtright flexibility is not essential as I only have 5 or 6 devices to control.
    Andrew
  2. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    I was thinking about the RU930 and was put of by the small screen. The 940 is more of a superior control IMO.
    If you are looking for a control which has a few hard buttons and are not to fussed with a big screen then go for the 930, if not then for the same sort of money you may as well go for the 940.:lesson:
  3. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    From the little I found out recently I think you'll find the 970 is just the latest variation of the 940 model which in turn replaced the 890. I think the main difference between the 890 & 940 was memory, 1Mb & 2Mb respectively. The 940 is colour where the 890 & 940 where B&W.
    The 930 is also refered to as the Neo and is less user configurable, that doesnt mean it's no good as it might be exacly what you need.
    I might be wrong with all that tho, as like I said it is from information I found when I was deciding what to to buy recently.
    I went for a second hand 890 in the end
  4. andy76
    andy76
    Thanks for the comments so far.
    In the process of looking around I have also come across the Marantz RC3200.
    Any comments on this model too?
    I know it is, like the Philips 930, a base model, but they seem to do what I want.
    More concerned about any issues with ease of use or problems users have encountered.
    The Marantz also seems easier to find stock of!
    Andrew
