which projectors have a 16x9 pc display
Discussion in 'Projectors, Screens & Video Processors' started by coolhand101, May 29, 2003.
  1. coolhand101
    coolhand101
    hi
    the ones i mainly need to know are
    1.sony vpl-vw12ht(im 90% sure it does)
    2.sharp z9000 and sharp z10000
    3.toshiba mt8
    i had a pdf sony 12ht manual but i cannot find this manual anywhere on the net again.
    the 9000 sharp im certain only had a 4x3 pc mode
    the 10000 sharp was to have this feature yet a lot of reviews say it still has a 4x3 pc output.
    the tosh, well for the life of me cannot find the user manual anywhere on the net.
    if anyone 100% knows please post
    thanks
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,140
    Surrey. UK.
    +1,953
  3. Kramer
    Kramer
    I think he's actually referring to 16/9 panel PJs which support 16/9 PC display.
    The HS10 is said to be only 4/3 with PC input, but can do 16/9 using Powerstrip etc...
    I think this is the case with most PJs, especially those with 1280x720 panels.
    The AE300 does, IIRC, "wide" PC display, but not 1:1 pixel mapping.
    Can't comment on those PJs you mention but be aware that even though the specs may say 16/9 PC display isn't possible, it usually is when using Powerstrip.
    :smoke:
