Which Projector?
Discussion in 'Projectors, Screens & Video Processors' started by CarlosBarlos, Sep 18, 2007.
  1. CarlosBarlos
    CarlosBarlos
    I supply the entertainment and advertising for a local bar and I've been asked for a projector to display the in house promotional tv on the building opposite the bar. (its the rear of the other building so just a big wall really)
    As with all businesses cost is important, we have about £400 tops and i'm looking for your advice on a suitible projector to do the job. I'd rather buy a second hand unit tbh, so i can get a better unit for the same price, idealy something very bright but not too fussed on quality, although it does need to display a rather large picture.
    So...
    £400 or thereabouts
    Very Bright
    Large Picture say 4-5 meters
    Distance 10 meters
    thats about it
    Thanks in advance
    Col
  2. CarlosBarlos
    CarlosBarlos
    no thoughts guys?
  3. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,026
    I would think that you'd need a 2000 lumen PJ for this kind of use. The quality isn't paramount, especially if you're projecting onto a wall(!), maybe a Data projector would work better for your application? They are designed to be used in ambient light, but usually aren't widescreen. See the link from Ebuyer as a £300 example (at least you have a good chance of the bulb lasting if you buy new, secondhand may end up costing more long term). This one is 2000 lumens and 4:3 screen. It is only 800 x 600 resolution, but this probably doesn't matter for your app. It only has VGA, composite and S video input from what I can see, but most DVD players have S video sockets (the better option than composite) and if you're using a PC to run it then VGA would be fine obviously.
    http://www.ebuyer.com/UK/product/105259
