Which Projector ?
Discussion in 'Projectors, Screens & Video Processors' started by Nobber, Nov 29, 2001.
  1. Nobber
    Nobber
    Nov 29, 2001
    321
    I'm looking to trade in my Sony 46" rear projection TV for a projector
    I have about £3K to spend can anyone give advice on the best for the money
    been looking at the new Sony VPL-HS1 and the NEC LT150
    also I believe there is a LT150Z does anyone know the diff
    any comments/advice would be appreciated
    thanks
    Nobber
  2. Nobber
    Nobber
    Nov 29, 2001
    321
    :D
    mmmm. perhaps I'll just buy them both, then smash the one I don't like with a hammer!!!
    Nobber
  3. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,285
    3
    +8,571
    You will get your hands on a Sony vw10ht for £3200 at the moment.
  4. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    I think the Z version has a zoom lens in place of the fixed lens.
    Jeff (Crawford) has a Plus equivalent to one of the NEC models. He seems very happy with it.
    Regards
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    The V3 1080 is going for a silly cheap price at the moment <£1800 INC VAT (correct)
