Which Projector
Discussion in 'Projectors, Screens & Video Processors' started by evan87_2003, Oct 26, 2005.
  1. evan87_2003
    evan87_2003
    Hey, im new to this stuff and i have got no idea about the specs or technical side of projectors, but im tossing up in between 2 (that are in my price range). in your opinions which projector is better for a small room(4.5mx3.4m).
    BenQ 5120 DLP Projector
    Texas Instruments DLP Projection System
    Native 480P (854 x 480) WVGA Resolution
    5 Segment Colour Wheel
    1100 ANSI Lumen Brightness
    2000:1 contrast ratio
    HDTV compatible up to 1080i
    DVI input available
    Includes remote control
    BenQ pb 6110 DLP Projector
    Native SVGA Resolution (800 x 600)
    Compatible resolution up to 1280 x 1024
    Brightness - 1500 ANSI Lumens
    Contrast Ratio - 2000:1
    HDTV connectable up to 1080i
    8 Preset Modes
    Remote Control included
    Thanx
  2. binbag
    binbag
    Jun 16, 2004
    1,717
    North Kent Coast, SE UK
    +81
    Usage?
    Mounting position?
    Throw distance / screen size?
    All would be useful to know. In any case the answer is the quietest one.
  3. evan87_2003
    evan87_2003
    hey,
    usage would be for mostly dvds, big sports events, and maybe some ps2. i will probably be mounted to the roof, about 4.5 metres from projection wall,
    the projection size would be roughly 2m by 1.5.just projecting onta a wall to start with, maybe buying a screen later on. the pb6110 is $1300(australian) and the 5120 is $1500(australian). im just wondering if there is much difference between them like $200
    thanx
  4. inzaman
    inzaman
    Dec 16, 2002
    8,018
    Derby
    +1,083
    Moved to Projectors
    :smoke:
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    If I'm not mistaken the 5120 is more suited to home cinema use because it has a widerscreen aspect ratio, the 6110 is probably more aimed at the business/presentation market because it is native 4:3 aspect ratio. Hence based on your usage requirements the 5120 would probably be more suited..PJ
  6. evan87_2003
    evan87_2003
    Thanks for that, i guess ill probablyt get the 5120.
    Thanks again
  7. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    The 5120 also has a 5 segment colour wheel to help reduce dithering artifacts, assist with black levels and may help with the rainbow effect.
  8. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Re; rainbow effect. The 5120 is not too bad with RE and I only notice it occasionally. It doesn't reduce the RE any more than my mates 4805 at twice the price (It was twice the price of the 5120 when he bought it. Significally reduced now).
    IMO, the 5120 is a great little starter PJ.
  9. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    Sorry, I was referring to the 5120 compared to the 6110. The 4805 uses a six segment, four speed colour wheel which should reduce the rainbow effect to virtually non-existent for all but the unluckiest people.
  10. Lucas
    Lucas
    Jun 29, 2005
    103
    +3
    The 5120 is a great PJ for the price it is sold these days.
    The only issue is RE. If you don't see it then you are lucky.
    I demoed it a while back along with an Epson TW10H. I settled for the epson because the RE on the Benq5120 was too much for me unfortunately.
    I see rainbows on even 5x DLP units costing thousands.
