I'm a complete newbie when it comes to projectors, never had one before and only seen one in action in a AV shop. After doing some measurements I can easily fit a 8ft screen in my room but what projector will be best? Which is the better DLP or LCD? I have a budget of around £1500-£2000 to spend on it. Any help would be great. Cheers
How far back can the projector go and how far back will you be seated? Some projectors can be closer to a screen than others so that info is important. You'll also need to sit at least 12ft away otherwise the pixel structure might be visible if you're sitting any closer. I prefer DLP myself, but some people see the rainbow effect with them so try to demo some before you buy. Gary.
Hi Gary From the screen to the back wall I have about 16ft to play with, so the seating can be placed at 12ft.
The Benq 7700 (DLP) looks like a good value machine, as does the Sony HS50 (LCD) so they might be worth investigating. Both are around £1500 but there are others that will suit if your seating and projector placement are flexible. Gary.
Take a look at the Infocus Screenplay 5700. You can pick a new one up from an authorized dealer within your price range.
.... but should have one tomorrow or monday I think. Having delivered from projectorpoint.co.uk who swore that they had in stock.
