WHICH PROJECTOR? pls help
Discussion in 'Projectors, Screens & Video Processors' started by sapkan, Jul 8, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    Hi, I am new to the business so please bear with me. I want to buy a projector for home cinema- watch TV (not the high def type but crappy cable one) as well as the occasional DVD. I was looking at the Sony HS-20, Panasonic Ae500 or the NEC 1100. The NEC is quite a bit more expensive and not readily available in my country but has to be ordered. The other two I can source. Questions:
    Which is better? picture quality is of course the primary concern
    Pls also recommend other options if I am on the wrong track with the above three. Mind you more obscure makes like infocus, benq sim2 etc will be hard to find in Bulgaria. Also DLP or LCD?
    Budjet is flexible but cant really go over J4000
    Please throw info at me cause I want to make an educated decision
    thanx in advance
  2. ShinObiWAN
    ShinObiWAN
    Oct 2, 2003
    749
    16
    Derbyshire
  3. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    it still doesnt tell me which is better. anyone to share his experience with either or ideally both
