Which Progressive Scan DVD player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by DrPepper, Jul 3, 2002.
  1. DrPepper
    DrPepper
    Oct 2, 2001
    3,398
    Barking Essex
    +276
    A friend is going to buying progressive scan dvd player.He can afford top of the range model. Would like PAL/NTSC progressive scan output?
  2. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Try the Arcam DV88 with progressive scan board for £1,299 or the Arcam FMJ DV27 for £1,599
    Both share the same progressive board and can handle PAL and NTSC.
  3. Laingy
    Laingy
    try the primare dv25, very good picture and sound, PAL and NTSC progressive
  4. Lowrider
    Lowrider
    Probably the best: TAG with PMS module...
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    How about the Phillips DVD-962SA
  6. Samir
    Samir
    How about the Denon A1, not shaw if it does Pal prog scan, or as Lowrider said how about TAG with the PMS mod
    Samir
  7. DrPepper
    DrPepper
    Oct 2, 2001
    3,398
    Barking Essex
    +276
    Thanks all for the replies.Looks like a few players to look into:eek:
