Which progressive DVD player..?
Discussion in 'Blu-ray & DVD Players & Recorders' started by pompeysteve, Feb 21, 2003.
  1. pompeysteve
    pompeysteve
    Aug 22, 2002
    623
    46
    Portsmouth, England
    +117
    This seems to be a popular topic, but despite my best efforts
    and trawling through the forums, I'm still stuck.
    Basically, which DVD player from these would you recommend?
    (I will be connecting it to a Panny AE100 projector via component)
    My budget is £350. I have just returned an Arianet 2255
    due to appalling picture quality and severe ghosting on
    Progressive Scan output.
    Kenwood DVF-R9050 £300 - Allegedly this can be modded
    via a DVD-R to support PAL Progressive
    Skyworth 1050P £200
    Philips 963SA £308 - Remote hackable for multiregion & PAL prog
    Toshiba 520e £200
    Any suggestions?...
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,662
    Newcastle
    +103
    The Tosh does not do Pal prog
    Do a search for the Phillips, seems to be a reasonable player.
    Done know anout the others
  3. norbert
    norbert
    pompeysteve
    You should probably add the Limit 9900SE to your list. I had one of these into an AE-100 and was very impressed by the pal progressive picture via component. I took it back due to a noisy transport on the two I tried but there's lots of people on the forum that are happy with it. Have a search.
    I think RicherSounds are selling it for £149 now but it does seem to be a 'love it or hate it' player. I bought a Toshiba 220e as an interim player until pal progressive becomes dead common.
    I've also seen mention on this forum of a Harmon Kardon and a Marantz player now outputting pal prog.
    Regards
    Richard
  4. pompeysteve
    pompeysteve
    Aug 22, 2002
    623
    46
    Portsmouth, England
    +117
    Cheers,
    I'll pop down to my local Richer Sounds then and try and
    demo the Limit player - although with my luck I will get
    a dodgy player! :mad:
    So now I have about 6 different DVD players to choose from..
    Life is oh so hard...
