Which Power Amps to Audition
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Henry, Oct 4, 2004.
  1. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    I've currently got a Denon AVC-10SE and am looking to add the extra rear channels but need a power amp to do so. I was wondering what kit I should be looking to audition?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,961
    +1,671
    A lot obviously depends on budget.....if you're looking to another 2 channels of power amp,then in the lower price bracket you have NAD,Rotel,Arcam and similar,with good sound quality and load tolerance,moving up from there,consider things like smaller Brystons...good value and excellent sound.
  3. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Would be prepared to spend up to about £750, any recommendations in this price range?
  4. alexs2
    alexs2
    Nov 13, 2002
    13,961
    +1,671
    Arcam do a number ranging from £500 to £850 covering your requirements,and the Rotel 1070 and 1080 fall into the same bracket.
    Both are good,solid performers,with decent sound quality,but be sure to listen to them,and as many others as you can before buying.
  5. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Parasound Halo A23. £750 new, £500 ish exdem.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,943
    The Borders
    +3,332
    Hello Henry
    We have a great offer on the Flying Mole DAD-M100proHT mono amplifiers in the Power Buy section.
    Two of these diminutive digital amps are well worth a listen - I have a pair we can send you if you want a home trial.
    See http://www.flyingmole.co.jp/en/products/dadm100pro/index.html
    Best regards
    Joe
  7. Henry
    Henry
    Aug 9, 2000
    2,194
    Hull
    +52
    Joe
    Cheers. :smashin: I'm looking at which speakers I'm going to get for the extra rear effects channels. Then I'll look to audition. Have posted in "Speakers" section. Will get back to you as soon as I've got the speakers sorted.
    Henry
  8. JonLeach
    JonLeach
    Sep 17, 2002
    756
    Deepest Darkest Yorkshire
    +22
    i would love to hear these can ypu send me a pair
    Jon
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,943
    The Borders
    +3,332
    Hello Jon
    Drop me a PM and we can sort out the details.
    Best regards
    Joe
    PS The October Issue of Widescreen Review has great review of the Flying Mole Digital amplifiers - I usually pick up a copy of this US magazine at out local 'Borders' outlet!
    See http://www.bordersstores.com/locator/sl_results.jsp?intl=1
