Quantcast
which power amp
cooky
Using an A85 amp,
Would a P80 be ok to partner with it, as i have never been over 50 on the loudness, do i need to use a P90.
Better, could i still get a P85. If so from where.
ANDY_DUTTON
All of our current stereo amplifers have the same gain so can be used with other amps in the range. Obviously you are likely to get better sound quality from the greater current drive from the P90, however I am sure you would also get a usefull improvement from the P80 if funds don't stretch to a P90.
The other option would be a second hand P85, ebay is probably your best bet for one of those. Or you may be able to find an ex dem unit if you are very lucky.
Regards,
Andrew
