Denon/ Marantz group describe power into 6 Ohms speakers loaded, that make it look impressive. Proper settings might be an issue, if all speakers are set to large for instance the amplifier get it hard to handle, even changing the center speaker settings to small could make significant difference,worth trying btw.Also active subs should be used with own on board amplifiers.I have tested several avrs Denon,Marantz,Arcam and Yamaha and stick to the last one.Denon gets hot but still within the parameters but it's not what I wanted,it should have space to breathe and cool down,I have no heat related issues with my Yamaha.As an author mentioned ,power amp is an option ,but stereo amp also give an opportunity to run 7.2.4 Atmos setup.
Another important details are the cables,room size,speaker placement etc.
As mentioned previously, I run Yamaha/Apollon combo on 7.1.4 setup for movies, for music I have additional valve amplifier for two front channels.Well it must be heard to fully justify this setup,for my ears I have never ,ever heard an Atmos like that before.My current setup is
Y/A combo plus KR 350i valve amp KR Audio VA350 Integrated Amplifier
speakers ,front L/R horn loaded Aria2 mk3
horns.pl
center Dali LCR Rubicon
6 x Dali Phantom s80 ,4 on the ceiling,2 on walls
2x B&W 707 on rear surrounds ,this gonna be changed for Dali shortly to match the rest sonically.
All goes on medium range ,thick pure copper cables.
So Yamaha works mainly as a processor ,feeding itself only 3 channels, also Phono stage is in use with my Rega P2 deck for vinyl .It took me 3 years of planning ,saving etc but definitely worth it.
Aria II MK 2 – hORNS
