tigertiger12
I have stated 7.2.4 as I am just stating I have 2 subs, I believe some people prefer to say 7.1.4 but I like to know how many subs people have, then I can ask which ones!
I have a Denon AVR X4500H with all Klipsch speakers setting up for atmos 7.2.4 but need another power amp as the denon is a 9 channel amp with 11 channel processing.
My speakers are: (some have not yet arrived but this is what I will end up with):
Fronts - Klipsch RF 7 III - 250W
Surround - Klipsch RP 8000 - 150W
Rear Surround - Kilpsch RP 8000 - 150W
Centre - RC 64 III - 200 W
Atmos - 4 X Klipsch RP 600M - 100W
SVS PB 4000
SVS SB 4000
I am looking for a 5/6 Channel power amp for the front, surround and centre channels.
I’m thinking say 200W per channel.
The Denon can handle the rear surrounds and the 4 X Atmos speakers.
Is it possible with the X4500H to send the first 5 channels via the pre-outs to a power amp and have the X4500H power the surrounds and 4 Atmos speakers. I’m thinking about the last pair of Atmos speakers which the X4500H can process but not power. How would I do this. Can I send the pre-out’s for these atmos speakers into another channel say the surround channel or is this done in the amp assign settings?
I also have a 6ohm 400W Eminence Lab 12 12” subwoofer in a large home made ported box I used to use in my car when I was very young, then I used this on my Kenwood Series 21 straight into the subwoofer speaker out which was rated at 50 watts and boy did it rock. If I don’t add this sub it’s not so important but as it is doing nothing at the moment I will use it if I can.
I suppose I could get a 6 channel amp and split one of the sub pre-out’s from the denon to add this as a 3rd subwoofer. Maybe if i get an amp I can upgrade such as the emotiva XPA Gen3, I could spread the cost by adding modules over time. I would prefer the single channel modules as the stereo modules are 65w @ 8ohms / 100w @ 4ohms.
I have seen the Emotiva brand from reviews of their centre channel on youtube and see they have power amps and even a ‘Build Your Own Custom Configuration’ amp. Maybe I could configure one with 6 single high power channels.
If not i'll get a power amp for the rear surrounds & 4 X Atmos speakers, this could be say 150w per channel.
What would you recommend? Any tips would be a great help, this is the first time i’m adding a power amp to a system.
I have no experience with power amps, so need all the advice I can get.
My budget is around £5 but I would stretch it to £10!
Say £1000 to £1200 max but as little as possible! Maybe I can stretch to more for the perfect solution.
SVS PB 4000
SVS SB 4000
