Which Power Amp for PA20r?
Discussion in 'TAG McLaren Audio Owners' Forum' started by Kish Kash, Oct 28, 2004.
  1. Kish Kash
    Kish Kash
    Hello,
    My system currently comprises the following:
    Pioneer DV-565 > TAG DAC20 > TAG PA20r > Rotel RB-03 > Tannoy R2 (6 Ohm 88dB)
    I'd like to get a matching power amp for the PA20r. The 60P is quite affordable now, but will it survive a couple of source and speaker upgrades? Is it substantially better than the RB-03? Will I get an extra £300-350 worth of dynamics, detail and control?
    Alternatively, should I spend £450-500 and go for a used 100P instead? Again, will it be worth the extra cash, or will the R2's (being a bit on the budget side :rolleyes: ) be holding things back?
    Also, why doesn't the 60/100P come with balanced inputs?
    Thanks,
    KK
