Which Plasma & Which Connection Box
Discussion in 'Plasma TVs Forum' started by Pasta Girl, Aug 21, 2004.
  1. Pasta Girl
    Pasta Girl
    I'm looking to buy a 42" plasma and everyone seems to recommend the Panny PW6.
    If I go for that what is the best way to connect up a DVD player, Sky+, DVD Recorder and an X-Box?
    Do I go for an I-Scan and connect the sources to that or can anyone recommend an alternative.
    Thank-you! :thumbsup:
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Simplest way is to connect them all to an auto scart switch box, then run a single scart to the screen. A step up could be converting the scart output into VGA using RGB-2-VGA converter (eg JS-Tech). Aspect ratio switching would now require a switch box (eg the one in the sticky thread at the top of the forum), if you don't want to watch everything in 'stretchy-vision'. That's a personal preference thing though.
    If you have a decent prog-scan DVD player, then you might want to connect this separately into the optional component connection board.
