Which plasma screen ??
Discussion in 'Plasma TVs Forum' started by dreads, Nov 2, 2005.
  1. dreads
    dreads
    Nov 2, 2005
    19
    3
    I am a complete novice and would like some advice
    I would like to buy a 42 inch plasma screen to use for watching sky, dvd's and using my playstation.
    I would also like to hook up my PC so that I can browse the web. My graphic card is a radeon 9250 and has a S Video and a DVI connector.
    I don't want a top of the range plasma screen and was considering the LG 42PX3RVA.
    Id this suitable for what I want
    Thanks in advance for your asistance
  2. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    LG's native resolution is not high enough for comfortable computing, it's like using VGA on your PC monitor...you could use a higher res from your computer but then I doubt you could read anything properly...also plasmas are susceptible to burn-in with non-changing screens so you'd be more comfortable browsing the Web on your standard PC monitor and useing the plasma just for PC and console games and video...
  3. dreads
    dreads
    Nov 2, 2005
    19
    3
    Thanks for your help
