Which Plasma for PC use
Discussion in 'Plasma TVs' started by Zebraman, Jun 17, 2005.
  1. Zebraman
    Zebraman
    Jun 13, 2005
    41
    Hi, I'm thinking of getting a 42inch plasma screen. I need one to connect up to my PC through DVi or standard VGA(preferable). I'm just not sure which would be the better screen for this. I'm thinking of the "Panny" 500 or Hitachi (Hitchy??) 7200.
    Will the PC pics fill the whole screen or just give me a 4:3 picture like it does on my PC monitor. Is it easy to watch .avi films on the plasmas this way?
    Help!
    Regards
    ZebraMan
  2. greyhorse
    greyhorse
    Apr 16, 2005
    445
    My panny pv500 gives a cracking picture, connected the xbox and it rocks.
    Also watched a divx movie from the pc and it played very well.
  3. Zebraman
    Zebraman
    Jun 13, 2005
    41
    Did the divx movie fill the whole screen? or was it 4:3 with borders?
  4. dilsher
    dilsher
    Zebra
    You can scale the picture using free software so no probs...
  5. Carlos13
    Carlos13
    Dec 11, 2004
    146
    16
    Peterborough
    dilsher, which software?
    I'd like to connect my pc into the plasma, but concerned about picture stretching - PC running at 1024x768 (4:3) onto widescreen plasma also 1024x768 - how does it work?
  6. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    I'm sure you have chosen plasma for a reason but if it will be heavily used for PC use than a LCD TV is more suited.
  7. dilsher
    dilsher
    Carlos
    Dload DScaler and Powerstrip which wil allow you to scale to any resolution and change aspect ratio etc...
    http://www.dscaler.org/
  8. Carlos13
    Carlos13
    Dec 11, 2004
    146
    16
    Peterborough
    Sorry if I am being thick, but isn't DScaler used for capturing external sources on your PC and scaling them for display on a plasma/screen?
    All I want to do is to see the windows desktop (and hence be able to use IE etc) on my plasma without the picture appearing stretched due to the rectangular pixels of the plasma...
    Powerstrip looks like the kind of thing though.
  9. dilsher
    dilsher
    yeps Powerstrip will do just that...
