Which Plasma for £5000
Discussion in 'Plasma TVs Forum' started by GarethRamsay, May 12, 2002.
  1. GarethRamsay
    GarethRamsay
    Jan 13, 2002
    A friend of mine is looking to buy a Plasma screen and has around 5 grand to spend. Does anyone have any recommendations? Do they all support PCs and if so what resolutions do they go up to? What else should I be looking out for?
    Any help would be appreciated, thanks
    Gareth
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The best PDP that I have seen for £5k is the NEC MP3 42" 16:9.
    It will support most video/PC inputs bar SDI (which you will probably never use anyway).
    Resolution is 848x480 pixels.
    If you are looking for a PDP with TV tuner as standard then look for the Pioneer 433HDE 42" 16:9 with TV tuner box, resolution is 1024x1024 pixels and price is £6.5k.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
  4. Mario Nicholas
    Mario Nicholas
    Apr 2, 2002
    820
    Surrey
    +86
    So would I...
  5. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    I think you'll find that the Pioneer 433 resolution is 1024x768
    As far as I know, only the Fujitsu sourced ALiS panels are 1024x1024
    Mark
  6. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I think the Fujitsu is only 1024*1024 interlaced.In progressive it's 1024*512.
    Regards
  7. YYZ
    YYZ
    Check out the Fujitsu 4229
