Which Plasma Do I buy!!!
Discussion in 'Plasma TVs Forum' started by watsonk, Jun 6, 2005.
  1. watsonk
    watsonk
    I am so confused... Which plasma do I buy?
    My eventual needs are for a 42" plasma wall mounted with a Sky+ and a multi region DVD player both SDI connected via a scaler. I initially just need my Sky+ box and Pioneer dv757 dvd player connecting to a panel either direct or via a scaler.
    I'm not to interested in having a mass of settings that need to be tweaked and tuned everytime I want to change a source.
    The setup needs to be Sky HDTV ready for next year.
    I am willing to spend upto £3000 on the screen and scaler. What is if any my choice?
    I have looked through the forums and plasma mags and the forums seem to fault everything and the mags praise everything. I thought I'd seen the perfect screen when I saw the Pioneer 43MXE1 but it's not HDCP compliant for Sky HD.
    Thanks in advance
    Kevin
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    HDCP is not obsticle it once was for the Pioneer speak to MAW
