Which Plasma and DVD combo ?
Discussion in 'Plasma TVs' started by MarkTy, May 20, 2005.
  1. MarkTy
    MarkTy
    May 20, 2005
    163
    16
    I'm just about to invest around 4-5 K in a 50"Plasma, DVD and surround sound system.
    I'm looking at the Pioneer PDP 505XDE, but need some advice on whether that's the best one to go for, and if so, what DVD and Surround sound to link in with it.
    I'll be using it to watch sky (and Sky HD when it launches) and DVD
    If I need to spend slightly more to get spot on picture quality etc, please advise
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the 505 is grand plasma but even spending £5k you are going to have a very video biased system especially if you want to add surround sound, the plasma to look at as well as the 505 are the PV500 panasonic and Fujitsu P50XHAUS. as for DVD choice that will depend on plasma speakers and amp need to be to taste and budget. Where are you as i am sure we can send you to a dealer who can arrange a suitable demo of possible kit.
