which pj to buy?
Discussion in 'Projectors, Screens & Video Processors' started by dragonheart, Aug 28, 2004.
  1. dragonheart
    dragonheart
    hi looking to buy a budget projector and would like a bit of guidance. Looked around the few shops we have here but didn't get very far, so have looked on the web have listed the following, any suggestions which would be better, mainly gonna be used for dvd watching and using my pc.
    Sanyo PLV Z1 - LCD projector
    epsom EMP-TW10H LCD WVGA 1000 ANSI Home Cinema Projector
    epsom EMP-S1H SVGA 1400 ANSI Lumens Projector
    infocus X2 DLP Projector 1600 ANSI lumens 800 x 600
    thanks
  2. Jim McC
    Jim McC
    Mar 28, 2004
    64
    Wisconsin
    Do you want 16:9 or 4:3 format?
    Do you want LCD or DLP?
    If you want 16:9 LCD, I would get the Epson TW10, that's what I am buying, based on all the reviews I've read. Here in USA it's called the Home 10.
  3. dragonheart
    dragonheart
    have read a little more and i am thinking that i will either buy one of the following, epson emp-tw10 or the infocus x2 dlp, the price is about the same price 589 pounds, which would you go four.
    thanks
