Which Philips player?
Discussion in 'Blu-ray & DVD Players & Recorders' started by stevie-c, Sep 2, 2005.
  1. stevie-c
    stevie-c
    May 27, 2005
    71
    I am torn between 2 playera at the moment - The Philips DVP720SA (£70 from Amazon), and the DVD963SA (£120 from Play.com). I will be connecting them via RGB scart to a CRT tv and using a CA 540R receiver. I will be using the player at least as much for CD as DVD.
    I was also condiering the CA 540D. This was mainly due to my receiver being the CA.
    Any advice/opinions would be greatly appreciated.
  2. Sofa1
    Sofa1
    Jul 1, 2005
    178
    +3
    as far as I can tell, 963 is a better solution for music reproduction, or audio if you like. it is reported as a fine choice for replay of standard audio CDs as well as SACD. on the other hand, 720 will play Divx, but no SACD, so it's up to your priorities to decide.
    but, both are a little bit old models and take this into account.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    963
  4. ddlooping
    ddlooping
    Oct 7, 2003
    1,446
    Essex
    +27
    It does play SACD. ;)
    It also does CD upsampling, which is supposed to improve the sound. :)
