Which Philips 32"?
Discussion in 'General TV Discussions Forum' started by Tan Coul, Jun 13, 2002.
  1. Tan Coul
    Tan Coul
    Having after some consideration and perusal decided to chance my arm with a Philips 32", does anyone have any thoughts on which model I should choose? The only ones I've been able to demo are the 9525, which I've seen on EmpireDirect for £870 inc delivery, and the 9625, which I've not found cheaper than Comet's £1012 inc. Is it worth the extra £140 to get an inbuilt digital tuner and have the possibility of a face to face if it's faulty, is either of them intrinsically more likely to have a knackered tube, or should I be considering another model in the same (-ish) price range? Cheers for any advice...
