Which pedestal stand for TH37PW7
Discussion in 'Home Cinema Buying & Building' started by stryda, May 19, 2005.
  1. stryda
    stryda
    Which is the correct pedestal stand fo the TH37PW7?
    TYST42PA20 or TYST42PX20.
    i have seen both quoted and dont want to end up buying the wrong one.
  2. sjp21
    sjp21
    Apr 10, 2002
    288
    York
    +5
    Its the TYST42PA20 you need. The PX20 is for the Viera range. Don't make the same (costly) mistake that I did!
