Which PCI-Express Video card for Sanyo Z2?
Discussion in 'Projectors, Screens & Video Processors' started by skygazer, Jul 9, 2005.
  1. skygazer
    skygazer
    Hi All,
    I am wanting to build a HTPC running MCE 2005. I am in Australia so PAL is our standard content format. Can anyone suggest a video card to use with my Z2 projector? Should I use DVI or component connection?
    My intended use is as follows:
    Z2 for DVD and HDTV viewing.
    Composite TV (68cm) for day 2 day SDTV viewing, navigation of MCE for music select and playback.
    HTPC will be connected to a receiver via SPDIF.
    So I need to be able to switch tje video output between the z2 and compsoite TV (hopefully through a key shortcut that I can link to a button on my programmable remote).
    Thanks for any suggestions.
