Which Panny PW7??
Discussion in 'Plasma TVs Forum' started by andloumeg, Dec 20, 2004.
  1. andloumeg
    andloumeg
    Jun 22, 2004
    55
    This may sound stupid, but I have just been over to Av Sales, and they are advertising the following:
    Panny TH42PW7B for £1745
    Panny TH42PWD7BS for £1845
    They are both silver, the spec is the same, so why are they different prices??
    Is one an import or something??
  2. AV Geeza
    AV Geeza
    Oct 10, 2001
    395
    Londinium
    +3
    42PWD7BS is the commercial screen whereas the other is the consumer one.
    Commercial is supposed to be better with more options I believe plus better back up.
    If the £100 difference is an issue try here :thumbsup:
    That should make your decision a bit easier! :D
  3. andloumeg
    andloumeg
    Jun 22, 2004
    55
    Thanks for the reply and the link
    Has to be silver though (same reason we have to have white loo roll in the bathroom...women!)
  4. AV Geeza
    AV Geeza
    Oct 10, 2001
    395
    Londinium
    +3
    andloumeg
    You can select silver in the options.
