Which panasonic
Discussion in 'Panasonic TVs Forum' started by Abbs985uk, Apr 28, 2005.
  1. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    Ok guys been reading the forums for a while now and decided probably better off getting a SD panel than a HD one bearing in mind ill only watch DVD and standard sky.
    Which panasonic do u recommend (seems to be the favourite brand) and i have a HDMI DVD player so would like to utilise that connection.
    Any Ideas and where is best to buy?
  2. Mr.G
    Mr.G
    I'm sorry,
    But then you'll still have to take a HD ready panel
    The PV500 is the one for you. I think it will probably go at EUR 2800,- via internet and will be in the shops somewhere next month.
    Can you tell me what kind of DVD player you use, that you want to make use of a HDMI connection?
  3. Abbs985uk
    Abbs985uk
    Apr 17, 2005
    59
    Birmingham
    pioneer 868 is the DVD player I have
    Guess it would be best to wait for the new HD plasma then.
  4. Mr.G
    Mr.G
    That's a great player. Have you i-linked it to a receiver and if so what kind of receiver. Because i've heard that the sound is fenomenal :thumbsup: :thumbsup:
  5. Mr.G
    Mr.G
    If you wait for the panny then you will have every man's wetdream in your livingroom
