Which optical cable for my Sky+?
Discussion in 'Sky Digital TV Forum' started by NinjaKi11a, Oct 18, 2003.
  1. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Because I am going to run my Sky+ through an AV amp, I am looking into optical cables, however I'm unsure of how much to spend. Does a Sky+ (and a budget amp - AX640SE) warrant an expensive cable? I don't mind spending a bit if I am garunteed a good sound. Alternatively will a cheapo Cambridge Audio £20 optical cable do the job as good as any other?
    Same applies for my X-box.
    Thanks.
  2. jonnyv
    jonnyv
    Mar 31, 2002
    2,256
    48
    +49
    I would stick to a fairly cheap optical cable, seems pointless in spending more than £30 on an optical cable.
    I have a qed optical cable and a cheapo one and i cant tell the difference
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Any one will do biut a tidy one looks better at the rear of the rack!
  4. phenom2003
    phenom2003
    How about this
    Rich
  5. wod
    wod
    Sep 7, 2003
    196
    +3
    that should be fine
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  7. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Great stuff! Thanks for the help.
  8. mastiff
    mastiff
    Ive just brought my optical cable from the most unlikely place our local B&Q depot. Its a maxview 1m cable (Toslink) with 3.5mm optical converters if required. Price £9.99.
    If all you need to do is make an optical connection from your sky+ box to the AV amp then this seems to be excellent value.
  9. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Maplins do similar cableto the1m maxview with changeable mini connectors for same £9.99.Does the job admirably.
  10. windfall
    windfall
    Oct 19, 2003
    2,409
    48
    LFC Kop End
    +61
    I have found some pretty decent cables for less than £10 on ebay, perhaps worth a search before buying from a shop.
    I just purchased a 10m S-VHS from tvcables (Ebay Shop) for just £5.75. They do sell TOSLINK as well!
  11. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    3m Toslink to Toslink complete with adaptors @ Homebase £6.99.
