Which one
PAULRYAN52
can anybody help me choose one of these amps
Yamaha RXV100D-TIT
Sony STRDA1200
Pioneer VSX1016
Yamaha DSPAX759SE
Denon AVR1907
Geege
Hi, I've got no experience with these amps, although I've heard Denon are better for movies than music. I believe the Yamaha got good reviews. I'm not sure, anyone out there that could suggest the best model?
It depends what you want it for? What feature are you looking for? For music, movies or both?
Sorry I've not been much help.
sk8
is it possible to go and listen to them and let your ears decide?
PAULRYAN52
itll be for films it needs to have 6.1 and 2 optical and 1 coaxil
PAULRYAN52
its not easy as im a chair and richersounds are the only place that sells them and i cant get in it
S
sunnyb4u
yeah erm i bought my yamahaha rx-v359 as i was on a budget and i got it and tested one from richer sounds in ealing as i took a few dvds and some iron maiden rock cds and i was blew away with the quality
for a amp costing around 130 quid its a bargain but the mistake i made was that even though the pictures on there website show it to have 4 banana posts at 4mm each, it doesnt since the caps are filled with plastic and the terminals are removed so you will have to unscrew the plugs and feed bare strands through the back or spade connectors for one set of speakers and the other set is for complete 5.1 and tose are only bare strands through a push connector
erm i love the amp and i gotta say with 3x component in and one out and it upscales to 1080i i think its are bargain and a bit heavy so take a car with you aye lad i hope that helps ya :)
adrianmurray
...the pictures on there website show it to have 4 banana posts at 4mm each, it doesnt since the caps are filled with plastic and the terminals are removed so you will have to unscrew the plugs and feed bare strands through the back...
Are you sure those bits of plastic dont come out? I don't have this amp myself but know wwith other amps you can just put something like a small screwdriver in and with a twist can pull the plastc out.
