Which one???
Discussion in 'Plasma TVs Forum' started by londynczyk, Jun 19, 2005.
  1. londynczyk
    londynczyk
    Hi! Can someone tell me what is a diference between TH42PE50 and TH42PWD7BSJ. Which one should I buy. I would like to know as well what BSJ letter means? Mostly I will use plasma to watch divx movies from PC. THX for answer.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PE50 is a "telly"
    PWD7 is a panel far more flexible and buiolt as part of a system not a "telly"
    which one to buy is up to you see the FAQ at the top of the forum:
    LEtters are panny codes, for Coutnry and accessories in the box BX is UK stock no accesorries BSJ is UK stock (Euro stock is "E" russian "R" IIRC) and ths SJ is a stand i think
