Justin1978
I am looking at buying a new tv and have short listed the following two, but am confused at the difference between them?
Samsung UE48H6670 or UE48H6400
I have read that there have been some lip sync issues with them but new firmware updates have solved this? Is there anything else to consider when buying one of these, or is the lip sync issue that bad that I should look at the panasonic range?
Any info would be greatly appreciated!
