Which one ?
Discussion in 'General TV Discussions Forum' started by slimtim, Oct 12, 2004.
  1. slimtim
    slimtim
    Oct 12, 2004
    Philips 32PW9309 for £650 delivered or Philips 32PW9308 for £600 delivered
    What is the difference between these two? does anyone know they look to have the same specs.
    I know the 9308 is limited due to lack of scarts but for that price i can live with a splitter box for the RGB between my dvd and satalite.
    My only worry is the reception on the sky isnt brilliant and does block up... is this just going to be made worse by all the gizmos of pixel plus etc. :confused:
    Cheers Tim
  2. mildred
    mildred
    I would go for the 32PW9309 as it is the replacement for the older 9308, and it looks better also.
    I was very impressed with the 32PW9309 picture when I saw it in Comet today. Far better than the new Pixel Plus 2, models.
  3. slimtim
    slimtim
    Oct 12, 2004
    hmmm... thats what i thought, however i may spend a little bit more on the 9509 as this can be had online now for about £750
    decisions decisions
