Which one?
Discussion in 'Home Cinema Buying & Building' started by Colonel Burton, Aug 14, 2004.
  1. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    I hope you guys can help i really can`t make my mind which system to go for should i go with the choice 1 or choice 2 or with choice 3 or is there something better you guys can suggest always willing to listen, many thanks for any replys
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Hmm all decent systems, but i think better can had for same money by not going for a boxed system, need some more info of what you have, what you want, what you are prepared to spend and any special requirements.
  3. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Hi, well what i have at the min is a humax freeview box my current home cinema setup is a philips lx8000sa which is what i`m wanting to replace, i`ll be getting a plasma screen in a short while aswell so i`ve got to get the system for about 800/900£
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK so think ahead to Plasma Purchase you are going to want a DVD with component, Amp with component video switching if possible, also one with delay, Youre not going to get all this for £8-900, I would say get a demo of as many as you can
  5. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    ok thanks, so how much would/should i be thinking of and what would that get in terms of item makes and models
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    erm difficult one mate suggest you go to a dealer and demo some systems, demo a couple on your current list, and then the next step up and so on look for an amp that does video conversion like denon 3803/3805, Yamaha RXV2400 etc also take a look at www.creative-audio.co.uk
  7. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Thanks m8, i know it can`t be easy recommending hardware i only ask because i`m out of my league with this stuff and don`t want to buy the next betamax video recorder lol
  8. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Would any of those i listed above give me any better picture quality and sound quality then my current philips lx8000sa ?
  9. cinesom
    cinesom
    Aug 30, 2004
    30
    Hi Colonel,
    A bit more pricey, but well worth it. Linn Classik Movie Di www.classik.com
    Speakers of your choice. Great HiFi and Movie plyer - Video outputs available Composite, RGB, Component etc Digital in (optical) if you have Sky +. 5 year warranty
    Small discreet and very powerfull
    Regards
  10. Colonel Burton
    Colonel Burton
    May 31, 2004
    678
    Sheffield
    +15
    Thanks for the reply, but i`m now going with the system in my sig ;)
