Which one?
Discussion in 'Subwoofers' started by ufuk, Jul 9, 2004.
  1. ufuk
    ufuk
    Hi, i have to choose one of these three subs; i'm aware that these subs are not more than booming boxes but i don't spend more money on a sub now. To help you advice; my system is : Sony STR 595 Reciver; Koda M604 front speakers and Sony SS CRF-305 surround speakers. My alternatives are:
    1. Eltax Atomic A8.2
    2. Jamo E.3
    3. Koda SW10
    Which one is the best to me?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    would it not be possible to wait a few monts and save some more for a decent budget sub?? MS309/BK XLS200 £219/£275 :devil:
  3. ufuk
    ufuk
    I have been working for 3 months and i have to buy lots of things so for a year or two; i have to buy and use one of these cheap sub's...Although i have more money; i limited my budget to these sub's... In a year or later, i'll ask for your ideas for a better sub but not today :(
  4. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,245
    2
    +3,772
    If you look in the budget sub test thread, you'll see that a Paradigm PDR10 was tested and it didn't disgrace itself. These turn up here and elsewhere for under £100 and would be an excellent starter. I would seriously advise looking for one of these over your shortlist. From your list I'd probably choose the Jamo.
  5. ufuk
    ufuk
    Thanks for the replies...
    i think i had to state i'm from Turkey...and unfortunately although i'm quite familiar with hi-fi systems; i have not heard about the models you mentioned...so please write full model & brand names to make my mind clear...i don't know if i can find them in Turkey; especially in Ankara... (but if you insist on a model, i can go look for it in ?stanbul... :smashin: )
    I'm going to keep Jamo in my mind :smashin:
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  7. ufuk
    ufuk
    Mordaunt short 309 is about 400-450 dollars!!! I have 150-200... :(
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +671
    Although it is a matter of your own personal priorities. I would strongly suggest patience. Save a bit longer and buy a known performer. If you buy a cheap boom-box you will regret it very quickly. Then you have to buy two subwoofers. The one you bought first and the next one that actually works as promised.
    Nimby
  9. ufuk
    ufuk
    Thanks a lot Nimby, you are right...i have to be patient and buy a better sub. But i have to buy lots of things these days; more essential then a sub. So this sub is only a temporary solution; i will buy a better one next year. So my question is; "which one is the best to use only one year?"...
  10. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    It would be better to go without than to use a 'temporary' sub or look for a second hand better model and stick with that. As you said you have lots of things to buy more essential than a sub :)
  11. ufuk
    ufuk
    Ok but it's a big problem to find a good sub in the second hand market in Turkey...
  12. ufuk
    ufuk
    What about JVC SPW 100 compared to the subs above? (koda,eltax,jamo)
