Quantcast
Which one.. Z2 or AE500 ?
dapex
This has been covered before and I'm sure a simple browse through the last months threads will reveal a lot of info, but here goes
Everyone will tell you to demo them both and see which one you prefer, there is no right and wrong, just personal preference. The ae500 seems to have more issues with vertical banding, the z2 seems to have more issues with dust blobs. Most people who have the Z2 say the lens shift is a wonderful feature and it is because of the lens shift that I will be buying a Z2. It makes the positioning of the PJ easier and in my case more wife friendly.
buns
ask a question:
1) do you have total control over where you can position the projector? If YES, go to question 2. If NO, but the Z2.
2) Can you see both locally? If YES got to 3, if NO buy whichever one you can view.
3) which one is cheaper? Buy the cheaper one!
ad
pgre
Thanks..
What your saying in summary as far as I can see is.. they are both as good as each other really apart from the Z2 has the ability to picture shift ...
As these are only 8-850 lumin projectors.. how dark will the room have to be to make it worth while ?
Also.
Has anyone tried them with PC games ? Are they any good..
Gillykid
Since the AE500 has got a bit of a bashing of late, I must say that having used it for over 2 weeks now I am really pleased with it.
The unit itself is small, sleak and looks great. Its very quiet even in high lamp mode, and a whisper in low. There are hundreds of things you can tweak for the numerous inputs it has, and I am not even including the "secret" menu.
The picture is very very good, there isn't a trace of chicken wire, VB is very minimal (on my model) if at all visible and has an impressive short throw. Dark scenes are reasonable and lighter scenes look great. Get a decent source to this projector and you wont be disappointed. I have tried a direct link with my PC and it is a very sharp image. I haven't got the room completly blacked and it still produces a vivid source. Obviously it is more impressive with lights off, windows covered on a dark night :D
I haven't seen the Z2 going, and I would suggest seeing both (side by side if possible), but I don't think you would honestly be disappointed with either.
Just my two pence ;)
buns
Originally posted by pgre
Thanks..
Also.
you got it! If the shift isnt needed, go for either the one you can get locally or the cheapest
ad
dapex
If the position of the projector makes any difference then it is worth while checking out the throw distance calcs on www.projectorcentral.com for me I found out i could have the Z2 a foot further away from the screen than the panny, this made a world of difference for me (it meant either the panny right above the sofa in full view or the Z2 a ft behind it hidden more.)
J
joe davis
i to Which one.. Z2 or AE500 ? up grade from my ae300 and i got the h30 dlp it's impressive.
Overall better blacks. and brilliant colours.and i see no Rainbows
dr no
A beginner myself I have just gone thru' almost identical dilemma.
A demo of both is a must!!!!
Eventually I went for the Z2 a week or so ago
(Great price from Technosound in Dunstable!)
Picture is great for the costs.
Set up and tweaking simple.
Positioning is very forgiving.
Lens shift is an EXCELLENT feature for me
Horses for courses really.
Good luck.
pgre
Still a little worried about the brightness.. whats the Z2 like in daylight ? Do you have to have the curtains closed.. ?
buns
neither will do well in daylight. The Z2 I can tell you for certain will not look good at all (when calibrated- most people cant do this properly). At factory preset the Z2 would almost be watchable in medium light
ad
A
am1001aa
I've an AE500 and I'd say its no good in daylight. You must have the curtains closed if you want a decent picture.
