Which One Would YOU go for?
Rizel23
Hi all, i have narrowed my search down for a new screen to these 3.
It will be needed to use the following:
Immediate use:
1) PC use for watching movies and TV shows
2) NTL Digital TV
3) X-Box 360
Future:
1) HD TV via Sky or NTL
2) HD DVD Player through PC, X-box or stand stand alone player
Screens (with staf discount and vochers)
1) Samsung LE40R73BD 40" LCD £954.49
2) LG 37LC2DB 37" LCD £897.10
3) Toshiba 37WTL66 - £899.09
none have a DVI connection, my PC has a 'Geforce 6800' graphics card with DVI & D-Sub out, currently using D-Sub to PC monitor (no DVI in) and DVI to my Acer 26" LCD. Seeing as none of the above screens will take DVI can i use a converter from DVI to D-Sub on either of the screens or my PC monitor, or another solution?
If anyone has any of the above screens and a similar set up please let me know what you think as I'm ripping my hair out trying to decide which one to go for, thanks, Sam
jsgreen89
Probably the Samsung, if it has to be one of those 3. Mainly because the Sammy has 1:1 pixel mapping through VGA, which will be a huge plus for PC use.
The Toshiba WLT66 series has a few problems when using PC Input at the native 1360x768 resolution.
Rizel23
Thanks, it does'nt have to be 1 of the 3 above, just they seem to be in my price range. Anything else i should consider for around the 1k mark?
