which one to get
Discussion in 'Headphones, Earphones & Portable Music' started by dowlinmp, Jun 12, 2005.
  1. dowlinmp
    dowlinmp
    Got my short list all about £150
    iriver h320se -on offer at Hughes for 149.99
    Sony hD3 in black same price from amazon and hughes
    Archos xs200 see this for 120 at datamind.co.uk
    Samsung YP20GS 169.95 not see any reviews, can any one point one out?
    Which one would you go for
  2. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Can you give me a link to the iRiver offer? That's a blinding price for the 320.
  3. dowlinmp
    dowlinmp
    Saw it in the shop in Ipswich, not on line. Ex display
  4. dowlinmp
    dowlinmp
  5. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    246
    19
    Auckland
    Thanks downlinmp.
    I'd personally go for the H320, but a lot depends on your criteria for selection. What are the important features you'd be looking for?
    If you can put something down, I'm sure it will give people a chance to answer you more fully.
  6. dowlinmp
    dowlinmp
    Basically i would like
    20Gb -they all have this,
    good sound -not sure which is best,
    and thats it!
    Read good reviews on Iriver and sony hd3, but can not find much on Archos and samsung model.
    Not bothered with classy looks, function over fancy stuff.
    I currently use a mini disc so this will be my 1st MP3.
    Ta
    Mark
  7. metal_jester
    metal_jester
    i would go for the h320, i own one and would go as far as saying its perfect
  8. dowlinmp
    dowlinmp
    Ok.
    So far two votes for h320. :smashin:
  9. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    For that price the H320 looks good. Basically it does everything you could want from a player. Not very well at times, but for 150 quid it's a bargain. The (full pack) H320 cost me £255 with case, display remote and cradle.
    Sound quality's not as good as the iPod, but it is better than the Sony NW-HD5 and although there's no multi-band custom EQ, you get to shape the sound in a wider variety of ways than the Sony.
    The video playback is pretty choppy, but the screen is pretty clear and vivid. You'll find lots of ways to change the way the player looks at misticriver.net. It's a geek's dream... but it does look geek as well, being ugly and comparatively huge.
    Battery run time's respectable. USB OTG's not as useful as I thought since it doesn't seem to talk to the vast majority of the stuff I wanted to OTG. There's a built-in mic for recording (at surprisingly good quality, albeit with some limitations) and also a built in separate line out for attaching external amps, headphone amps, etc. Line in recording quality is OK but can be tricky to get right.
    I mean, nothing else for the money you're getting it for will offer the features of the H320 and it's build quality, which is high. It is however ugly, huge and none of the multiple functions on offer are that well thought out in comparison to some other players, although the features are perfectly usable.
  10. dowlinmp
    dowlinmp
    Thanks for help. Picked up the last one in the shop, ex display with no charger. But they found one that works and they knocked of a further £20!!! bargain.
    radio reception a bit noisy.
    Sounds better than for MD N710. Which is now up for sale
    Not tried video yet and am currently ripping loads of cds..Thanks
    Any idea where i can get the remote control from?
  11. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    There are three remote controls for the H320. Two of them are quite readily available in the UK... try advancedmp3players and so forth.
    In the UK the display remote control you can get for the H320 is the H1xx / iMP-550 remote. It works fine, but it's a holdover of moronic iRiver design in that you can't plug in most headphones into it because of the shape of the connector socket. Buy the headphone socket extension cable at the same time (about an extra fiver).
    The non display one is the one referred to in the manual.
    There is a Korean H3xx display remote which is specifically for the players. To get that, go to MisticRiver in my sig, go to the H3xx forum and look for the Display Remote ordering thread.
  12. dowlinmp
    dowlinmp
    ordered the one on advanced. Got an extension lead and i hope this works. what's problem with socket? The lcd display one is not in stock at mistic. Non lcd will do for time being. Ta
  13. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,258
    +64
    The non display remote doesn't need the extension lead.
  14. dowlinmp
    dowlinmp
    cheers.
    Thanks all
    Regards
    Mark
