Which one TH-42PHD8 or TH-42PWD8
Discussion in 'Plasma TVs' started by m1k33p, Sep 28, 2005.
  1. m1k33p
    m1k33p
    Im trying to decide which one to go for, i will be using it for movies, sky + and the xb0x360 when it arrives. Will the TH-42PWD8 be able to make proper use of the HD output from xbox360 or am i better off paying the extra cash for the HD version? :rolleyes:
    Thanks in advance!
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +645
    If you can afford the HD8 then go for it, not really for resolution but it gives a better image, less banding etc.
    You will only always wished you had if you don't! :)
  3. theo cupier
    theo cupier
    Sep 18, 2004
    1,649
    63
    Amersham, Bucks
    +113
    The only real downside to the PHD (other than the price) is the noise. It's a little noisier than the PWD but nothing too bad.
  4. zedzed
    zedzed
    Jul 12, 2004
    817
    Linlithgow (nr. Edinburgh)
    +13
    The HD will display a better picture for xbox 360 (progressive 720p) than the PW8. Whether you'll really notice (the graphics on the 360 will be better than anything you've seen before anyway!) ... and whether it's worth the money ... well ... perhaps a demo at your local hi-fi/av store would help?
    ZedZed
