Which one of these players is best?
Discussion in 'Blu-ray & DVD Players & Recorders' started by sund, Mar 8, 2002.
  1. sund
    sund
    Which player would you go for and why?
    Arcam DV88 or Toshiba sd900e? I can get both players for the same price.
    How do you rate each player out of 10 for sound and also for picture?
  2. Arthur.S
    Arthur.S
    Sund,
    You need to do some homework of your own! Try doing a search on google.co.uk for reviews on these players. Also try the reviews on this site from HCC mag.
  3. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    Pioneer 747A :D
    why? Because its the nutz :)
  4. marcoeser
    marcoeser
    Jul 17, 2000
    342
    Gareth,
    that really depends on your priorities doesn't it. If you need a multi-purpose player that plays all formats then I'd agree, the 747 would be a good choice.
    Check Hi-Fi News' review, it's worth read.
    marc :)
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Marc has a good point for you Sund. If you want an all in do everything player then it is the 747, being the only real choice. If you are after quality picture and sound on DVD (and possibly DVD A) then it is a whole different ball game. You two mentioned players will masacre the 747 for breakfast but they won't do SACD.
    Both the Tosh 900 and Arcam 88 are quality bits of kit. Personally I would go the Arcam route because of the support Arcam has been proven to deliver, particularly on this forum. You will not go too far wrong with either, both quality on sound and picture.
    Don't forget the Arcam is modular and upgradable.
