Question Which one is the best?
vickster
What uses? Viewing angles? Lighting in room?
tvdavid
Samsung ue50tu8500 be best if in a darker room.
Dodgexander
50" TVs in your list are VA
49" IPS.
SM8600 probably best bang for buck since its a 2019 model with a 120hz panel. The others are overpriced, lower range 2020 models and shouldn't be considered right now. Prices on 2020 models are too high.
See comparable ranges between the years here:
If I was buying, I'd avoid all the TVs you are considering and opt for the Hisense U7Q or U8Q instead (and buy at least at Black Friday or later).
arthur1967
49" IPS.
Thanks! I am little bit worried looking at reviews about motion handling of the U7Q since I watch a lot of football. Let’s see ;-)
Dodgexander
Motion is not a strong point of the U7Q, or any TV of similar calbre (60hz VA type panel). LG SM8600 will be better in that respect.
But motion is subjective. If you worry about the early problems with motion reported here on the forum, contact Hisense to get the updated software. Not sure its available OTA yet.
