Which one for High End Gaming?
Discussion in 'What Is The Best TV For You?' started by pan1950, Jul 17, 2015.
  1. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
  2. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Get Sony for low input lag. 55w829, £649 from john Lewis, delivery and 5 year warranty. No quibble returns of open box if not satisfied
  3. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
  4. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Why when they are not actually the best TVs for gaming...which you say is high end (although not sure what you mean by that)...if you want low input lag, Sony are the brand to go for (20ms vs 40 for the Samsung for example)
    Unless the others offer another feature the Sony doesn't (catch up TV maybe)
  5. T7BSY
    T7BSY
    May 29, 2015
    282
    Brynmawr
    +27
    For PC gaming your should get a PC monitor for the best experience, lag is a game killer if you play online, MS on tv's are mostly worse than what the try and have you believe too :)
  6. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    If you are refusing the Sony, then the LG of those two.
  7. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    Ok i found this Sony T.V.
    '''Sony KDL-55W829B 55" Smart 3D LED Full HD'''
    I cannnot find the inpout lag though, but it looks ok for Gaming.
    Guys your more expert than me, so you may find the inpout lag ms.
    What is your opinion? Is this T.V. good for fast Gaming?
    If you like and agree with this one i am ready to buy it tomorrow.
    I wait for your responce\advices YES or NO.
    I added few websites with the specific model.
    http://www.sonycentercy.com/sony-bravia-led-kdl55w829bb-889.html#.Vau19nu1f_H
    http://www.stephanis.com.cy/nqcontent.cfm?a_id=6315&p_id=320146
    http://www.public-cyprus.com.cy/pro...5w829b-55-smart-3d-led-full-hd/prod6370120pp/
  8. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  9. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    Yes that's the one you should go for.
    Input lag is about 22ms.
  10. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    Ok, tomorrow i'll buy the Sony KDL-55W829B :thumbsup:
    Now one a little difficult question\request:
    The input lag of this old Samsung tv LE40A656A1F???
    Why i ask? Is what i use right now and i never found any info about the input lag.:confused:
    Just from pure curiosity i want to compare the ms between my old Samsung and my new Sony.
  11. desinho
    desinho
    Sep 22, 2014
    1,406
    83
    +373
    22ms is with the new input lag device tester which was not around when your model was reviewed. Measured as it was back then the Sony would have 8ms and yours, in Game Mode, ~30ms or 60ms in a different mode (with Motion Plus disabled) ...
    http://www.*/Samsung-LE40A656/Picture-Quality.htm
    But you can't say 22-8ms = 14 so yours would score 44ms with the Bodnar device test; some score better than expected and others worse ...
  12. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    I update the Sony KDL-55W829B firmware and now i have the PKG2.294EUA.
    Strange, in their support website they have the 2303EUA.
    Maybe this happen because i update via the direct internet connection and not with the usb method?
    Sony Support
  13. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  14. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    The T.V. stand of my Sony KDL-55W829B looks and it is too weak. [​IMG]
  15. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    To weak?
  16. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    Yes, Weak, Thin, Feeble.....
    Only 2 small screws, 1 each site to hold that BIG size T.V.?
    Is that safe?
    KDL-55W829B stand
  17. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    Yes, its not a problem.
    Was not a problem on my W8 form last year, and not a problem no this years W755.
    Both in 55".
    Why do you think that is a problem?
  18. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    It looks like..... it will fall down with just a little touch???
    Well....as i said it looks too feeble.
  19. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    Yeah it looks that way, but it wont. Not much movement in mine when i am trying to push it a bit.
  20. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    The reason....
    I have mine standing on a table with weels and i move it alot around because i have it on the bedroom for gaming-movies and such and sometimes i need to move it back because is too close to my eyes for some movies.
    Thats why i am worried because i need to push it alot back for movies and forrward for games.
    Ofcourse i be carefull but it feels to feeble and shaking.
    I dont know, maybe i worried too much?
  21. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    Yes you are to worried. I was worried in the beginning as well, but after owning two sets it never became a problem.
    Oh btw, the first stand i had on the W8 was faulty so i got a new one. It was bent so the tv was leaning towards me, a lot.
  22. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    My tv is leaning towards me, a little, is that normal?
  23. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    well a bit maybe. Can you take a picture?
  24. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    Ι have the T.V. transformer on the table, i find the transformer a little bit warm, maaaaybe a little hot. Maybe a normal thing also?
    Maybe i'll stick some rubber legs under it for better airflow.
  25. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    That looks pretty normal to me.
    Dont know about the transformer, mine is behind the TV bench.
  26. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    The T.V. has 4 1-2-3-4 HDMIs is there any specific HDMI to connect the PC for the best picture quality? Or all are the same? For now i use a high speed HDMI cable and i have my PC connected to HDMI 3 because HDMI 2 is a little bit loose.
    (I dont interest for the sound through hdmi because i use logitech PC speakers).
  27. BigBadAde
    BigBadAde
    Oct 22, 2014
    146
    +13
    Makes no difference as far as i know.
  28. pan1950
    pan1950
    Jul 17, 2015
    14
    4
    Daxame
    Is there any way to say Thanks? Rep+ something like that?
  29. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Try the different sockets and see which seems best to you?
  30. Trollslayer
    Trollslayer
    Feb 11, 2007
    27,227
    Poole
    +11,859
    If you hover just above the Quote/Multi-quote buttons some icons will appear. The one that looks like a medal is the thanks icon.
