Udate.
OK guys, had a bit more time to evaluate the Rotel A11 tribute today and compare it with my Denon, and it seems I may have been a bit premature in my initial assessment . Unfortunately this amplifier simply does not have the Kahoonas to power my DBR62 Ref speakers properly.
On lower volumes under 65 on the Rotel (which is how I first tested it) it sounds very good but when I start to push it a bit, the treble hardens up and sounds a bit metallic.
Playing Steely Dan's track Jack of Speeds there is hardly any low end grunt, the bass seems to disappear or not get any punchier like it does with my Denon, with the Denon as I push the volume up the sound remains beautifully sweet and clean and I start to really feel the bass slam through my sofa and chest, this is completely missing from the Rotel, its delivery seems very lightweight. If I had purchased the Elac BDR62's with this amp I would have thought the speakers were to blame but I know that's simply not the case, the Elac's can sound amazingly dynamic and punchy and also go quite deep with bass.
I tried a few more tracks and it was the same, OK at lower volumes but as I turned up the wick to 70 and beyond the bass did not seem to get any louder (I had to push the bass control up to +4 to feel any real low bass, this is quite weird because the Rotel does go quite loud, I pushed it quite hard this afternoon but it just doesn't have weight and heft to the sound as the Denon. It's almost as if someone has removed the six and a half inch woofers from my speakers and replaced them with 4 inch woofers and then bunged the ports up, what bass there is, is quite melodic and tuneful but lacks real weight.
I'm guessing the Elacs really do need loads of current to get the bass cones moving and the Rotel just can't supply it, either that or the amp has been designed to produce light fast bass instead of heft.
I do like everything else about though, the midrange is airy and light, the soundstage is quite wide and open, I love how you can adjust everything with the remote control also. There was some odd thing going on with Bluetooth when playing qobuz from my streamer, every time a track changed I heard a relay clicking in the Rotel, strange as this didn’t happen when I used spotify over Bluetooth.
I will still keep the Rotel for a while or maybe just give it to my son as he doesn’t have a Bluetooth amp and maybe it would work better with different speakers, so I am left a little disappointed, but hey it's not an expensive amp so maybe I'm am being a little too critical.
