Which Of These VGA Leads Will Do?
Discussion in 'Desktop & Laptop Computers Forum' started by Rizel23, Dec 6, 2003.
  1. Rizel23
    Rizel23
    Oct 11, 2002
    736
    +21
    Hi all, as the above, got bored yesterday looking for a decent PS DVD Player, reading reviews most bid range players had draw backs so i decieded to read some guides and hook up an hold'ish PC to my Panasoinc PTE 100 Projector.
    Wow, thats all i can say, set it up with power strip, spec wise Graphics Card was only a Gefore 4 MX but the picure quality was amazing compared to what i had been using!
    Now my main PC is going to be silenced with new fans and Power Supply, has a P4 2.4Ghz CPU, 512MB RAM & A Radeon 9600 o hopfully picture quality will be even better.
    I need a 10 Meter, or 7.5M VGA lead, have found these 2, now problem is it will be running by a power & Broad Band cables, can anyone advise which is best to go for? Seeing as the Premier Gold cable is 50% more in price nearly is it worth it? Cheers, Rizel
    http://www.lindy.com/uk/productfolder/03/37345/index.php
    http://www.lindy.com/uk/productfolder/03/37248/index.php
  2. Kramer
    Kramer
    I'd recommend the triple screened premium gold VGA cable, eventhough it is nearly twice the price :(
    Really sturdy construction & never read of one complaint about it.
    Blue & gold - looks snazzy too :eek:
  3. nutcase_1uk
    nutcase_1uk
    Apr 15, 2002
    479
    Essex, unfortunately
    +3
    Aargh, why can't people make their websites work with opera :(
    Anyway, I have a 5m version of the blue/gold cable. It's excellent. The gold connectors take some getting used to as they're a bit bright, but as they're mostly hidden, it's not a problem :)
    Picture wise, zero problems at all for me, and the cable is trapsed over the floor, past a PC and a couple of mains adaptors. I've used cheaper ones and had ghosting in less harsh environments.
    Oh, and I've even run the thing over with my chair a few times, and it seems to have survived fine!
