mysticalice
We moved into a house that has a living room that backs up to the outside pool area. I'd like to get a receiver that supports dual zones (either powered or at least a line out for it), so we can have speakers in the living room, and speakers outside.
I've narrowed my selection down to either the Denon AVR1913 or AVR1713. The only difference between the two is one of them (the 1913) has a powered zone 2 - where i'd just have to connect the outdoor speakers, and the other (the 1713) has a RCA 'line out' for the second zone.
I have no problem getting an amp for the second zone, but my two questions were:
1) On either receiver, is it possible to play a separate SOURCE for the second zone? For instance I may want to have Pandora playing in the background for the living room, but playing a CD or other input for the second zone
2) Which should I go with - the powered zone 2 or line out zone 2 (needing a power amp)? I do worry that the 'powered zone 2' will not be loud enough for us, as it's going to have to power 4 speakers outside (two on the one channel, hooked up in paralle, and two on the other channel, in parallel). I don't have a problem getting an amplifier (like an Audio Source 100 pro amp).
Open to any suggestions
